1989 Oldsmobile Delta 88 turn signal diagram
1989 OLDSMOBILE DELTA 88
17,500 MILES • 6 CYL • 2WD • AUTOMATIC
DISCENNA57
  • 8 POSTS
I was fixing my sisters steering column and when i removed the cancelling cam, a piece (not sure what it is, must be for the actual lever that activates the turn signal) fell out and im not sure where it goes. All i need is a diagram of the turn signal cam to show which piece go where (including the parts that connects to the turn switch)
Thanks for your help!
Aug 25, 2010 at 3:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Is this for a non-tilt or a tilt style steering column?
Aug 25, 2010 at 4:01 PM
DISCENNA57
  • 8 POSTS
this is tilt steering. I bought a chiltons manual hoping that it would have a diagram in there but nothing. i took a picture of the piece hopefully you can tell me what it is.
https://www.2carpros.com/forum/automotive_pictures/379303_20100825_173543_1.jpg
https://www.2carpros.com/forum/automotive_pictures/379303_20100825_173559_1.jpg
and again thanks for your help!
Aug 25, 2010 at 4:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
see if these images help any
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2625.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_2_124.jpg
Aug 25, 2010 at 4:54 PM
DISCENNA57
  • 8 POSTS
nice! thank you very much but where the piece fell was in the compartment between the lever (6) and the arm signal switch (3). Iin that compartment i assume holds the mechanics that moves the turn signal cam. if you have any insight on where that part might fit that would be great!
thanks again for the diagram!
Aug 25, 2010 at 6:14 PM
