Transmission problem
1988 Oldsmobile Delta 88 6 cyl Front Wheel Drive Automatic 100k miles
Recently my car has been unable to get into higher gears. If I put the car in Park, Reverse, Neutral, 1st, or 2nd, it runs accordingly. If I put it in Drive or Overdrive, it will start off driving normally, but when it disengages the first gear, it doesn't go any higher. Any pressure on the gas just causes it to rev as if in neutral. When the car slows to about 5 mph, it goes back to 1st gear.
Jun 22, 2009 at 9:27 PM
