Engine Mechanical problem
1987 Oldsmobile Delta 88 6 cyl Front Wheel Drive 120000 miles
I am working on a 87 olds delta 88 3.8 for my cousin, she drove it a short drive and shut it off for about 2 hours, when she went to start it, it just cranked, and would pop occasionaly. I checked it out and it has no compression but you can see the rocker arm moving in oil fill hole while cranking, I am pretty sure the timing chain/belt has jumped. I am wondering if this will usualy bend valves? And if there is any way to check without tearing the heads off. thx for any help
Jan 13, 2009 at 4:43 PM
