1986 Oldsmobile Delta 88 Will not crank?
1986 OLDSMOBILE DELTA 88
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOSH72
  • 11 POSTS
Turn key to start car and nothing. No click, no crank. Have replaced the ignition switch and starter solenoid. Battery voltage @ 12.6V. Took starter off and bench tested and it engages when hooked up to power. Any other ideas? Thanks!
Aug 1, 2009 at 7:14 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Have you tried to jump start it? Just because the battery shows 12.6v (a full charge) doesn't mean the battery isn't bad. A multimeter will not show you what the cranking amps are and if there are No or they are very low it can cause your problem.
Also check your ground wire make sure it is clean and making good contact at engine block. A bad ground could also create your problem.
One more thing to check is the Neutral Safety Switch. Try putting the gear shift into neutral
and try to start.
Aug 1, 2009 at 7:23 AM
TOSH72
  • 11 POSTS
I have tried to jump start it with no luck. I have also tried shifting into Neutral and starting and get the same result (nothing). Will check the ground on the block.
Aug 1, 2009 at 8:22 AM
OBXAUTOMEDIC
  • 3,711 POSTS
If that check or look good check the Fusable Links... In diagram check Fuse link "A" . I am not sure if they are labeled, so you may need a test light to check either side of link.
https://www.2carpros.com/forum/automotive_pictures/188069_86delta88fuselink_1.jpg
Aug 1, 2009 at 8:39 AM
TOSH72
  • 11 POSTS
Fusible links checked out okay. Finally got a second pair of hands to assist so I could do some further probing and found that when I turn the key to start I have power up to the neutral safety switch at the yellow wire but nothing coming out of the purple wire that goes to the solenoid. The neutral safety switch is brand new as of 2 days ago. Any ideas?
Aug 4, 2009 at 11:03 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, Do you have a Digital Dash? And did they ask you that when you got the switch? If they didn't ask you may have gotten the wrong switch.
Will check some other possible causes and get back with you.
Aug 5, 2009 at 6:21 PM
TOSH72
  • 11 POSTS
Do not have the digital dash and did get the switch for the non-digital dash.
Aug 5, 2009 at 7:43 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, turn headlights on and try starting the car have someone watch the headlights. Do they continue to shine bright with no dimming? If so try adjusting the Neutral Safety Switch.
Also does your vehicle have the Brake Pedal Safety Switch. If so it could be the cause.
Aug 6, 2009 at 8:31 PM
TOSH72
  • 11 POSTS
No dimming of the lights when I tried to start the car. Adjusted the neutral safety switch from one end to the other and many spots in between and still nothing. I could find nothing about an interupt switch on the brake pedal for starting in Mitchell On Demand.
Aug 12, 2009 at 8:58 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, well I'm leaning toward the possibility that you got a defective Neutral Switch. It doen't happen often but it does happen. Especially since you said that you were getting power to in just not out of it.
Aug 13, 2009 at 9:30 PM
TOSH72
  • 11 POSTS
I jumped the neutral safety switch pigtail and am now getting power down to the solenoid but it still doesn't click or anything. So I tried using a screwdriver to jump the starter and it still does nothing and the spark is really weak. I am going to replace the starter and see if that doesn't fix my problem.
Aug 13, 2009 at 9:57 PM
TOSH72
  • 11 POSTS
Now getting it to crank with the neutral safety switch jumped but now it seems that it isn't getting a spark. I was wondering if I should include the the wire that goes to the ECM in the jump?
Aug 19, 2009 at 11:24 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Did you try reconnecting the Neutral Switch?
Aug 20, 2009 at 8:42 PM
TOSH72
  • 11 POSTS
Keeping the jump in place and reconnecting the switch?
Aug 20, 2009 at 10:56 PM
OBXAUTOMEDIC
  • 3,711 POSTS
No, I would first try it without the jumper.
If won't start the reconnect jumper.
If starts then you have a defective neutral switch.
Aug 21, 2009 at 9:55 PM
TOSH72
  • 11 POSTS
With jumper & pigtail unplugged it was cranking with the key. Plugged pigtail back into neutral safety switch without jumper and would not crank or click. Put jumper on plugged into neutral safety switch and would crank using remote starter switch, not with key, and still no spark. Unplugged pigtail and kept jumper in and now will not crank with key but will with remote starter switch and still no spark. I checked the power going to the coil and to the electronic spark module and have power to both.
Aug 21, 2009 at 10:08 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, I am going to ask my fellow techs for some input here. I am better with wiring hands on them I am trying like this.
Aug 22, 2009 at 8:34 AM
TOSH72
  • 11 POSTS
I completely understand, and thank you.
Aug 22, 2009 at 9:14 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, got one in agreeance that you got a defective switch. Will wait for couple more responses before making decission on replacing it again.
Aug 22, 2009 at 10:29 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Well, guess only going to get one response from my call for input. Anyway, I believe you got a defective neutral switch.
Aug 27, 2009 at 9:24 PM
TOSH72
  • 11 POSTS
I finally gave up and took to a local mechanic. It turns out it was the starter and the crank position sensor. I just thought you would like to know and wanted to thank you for all your assistance.
Aug 30, 2009 at 10:47 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Sorry wasn't able to help get the vehicle diagnosed and fixed without you having to take to garage. Wish I had gotten more input from the other techs here may have been able to track down that it was the starter and crank sensor.
Wish I was as good with electrical hands on on not.
Glad it is finally fixed....
Aug 31, 2009 at 9:37 PM
