Remove the door panel. THere are two wires that go to the window motor. One gets power in the down position, the other in the up. Check if you are getting power when you switch them up. If you are, replace the motor. If there is no power, chances are the switch itself is bad.
Let me know what you find.
Apr 12, 2010 at 9:29 PM
