1986 Oldsmobile Delta 88 3.8l eng. code41 mileage: 155000. I recently replaced the cam position sensor after several stalls and code 41. The old sensor had severl cracks in the epoxy, and at first the new sensor seemed to work fine(I let it idle for ~15 min until the radiator fan turned on, and everything was still OK...no failure codes etc.). Well, unfortunately that didn't correct the problem. The car stalled ~1 mile from home and wouldn't restart for ~15 min. It did make the short drive home but now sits in the driveway, and yes the code 41 is back. Do you have any further suggestions?
Thanks
Thanks
May 19, 2009 at 6:15 PM
