1971 Oldsmobile Delta 88 engine dies/loses power
1971 OLDSMOBILE DELTA 88
51,000 MILES • V8 • 2WD • AUTOMATIC
MCGREW77
I recently had this car tuned up, new fuel filter etc. It had been sitting for many years without being driven. When I approach 50 mph it loses power and almost dies, sometimes it does die. Also when I accelerate from a complete stop it hesitates, then kicks in. Do you know what this could be?
Thanks
May 27, 2010 at 11:25 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 30, 2010 at 2:30 AM
