1999 Oldsmobile Cutlass TROUBLESHOOTING OVER HEATING PROBLE
1999 OLDSMOBILE CUTLASS
60,000 MILES • 6 CYL • FWD • AUTOMATIC
AEMMILENE
ALREADY REPLACED WATER PUMP, THEMOSTAT, FUSES, RELAYS, HEAD GASKET. NO LEAKS IN HEATER COIL, STILL SMELLS OF ANITFREEZE,
STILL RUNS ABOVE NORMAL TEMP. AND SOMETIMES OVERHEATS. WHAT ELSE CAN I CHECK?
Aug 28, 2008 at 9:20 PM
MMPRINCE4000
  • 8,548 POSTS
Flush the cooling system, including draining the block. If equipped with Dex-Cool you may want to inspect the intake manifold gaskets. Check with GM about a recall concerning this problem.
Aug 29, 2008 at 5:28 AM
SERVICE WRITER
  • 9,123 POSTS
www.dexcoolsettlements.com
IS the radiator cap holding pressure?
Make sure you bled all the air out.
Did you shave the heads when doing the headgasket job?
Aug 29, 2008 at 5:34 AM
