1999 Oldsmobile Cutlass Car still over heating
1999 OLDSMOBILE CUTLASS
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
FHEY
  • 5 POSTS
I just recently got this Cutlass, and my neighbor and I have been working on it to get it going. First we had to change the battery which was easy. Then we found out after driving the car for about 10 minutes, it would red line heat up, so we decided to change the thermostat. After the painful replacement, we flushed the coolant and hoses out, and gave her another shot. Given, I've driven for over 30-40 minutes just cruising around and the car has NOT gotten to red line. I guess that's a plus, although the car does still run pretty high. About a bar higher than half way, what I'm wondering is will this eventually work it's self out? Or is there another fix I need to make? Thanks so much for any help.
Sep 12, 2010 at 7:49 PM
Try bleeding the cooling system and see what happens
Sep 13, 2010 at 3:03 AM
FHEY
  • 5 POSTS
What do you mean bleeding? We flushed it all out with water.
Sep 13, 2010 at 3:23 AM
Meaning removing the air out of the cooling system
Sep 13, 2010 at 9:13 AM
FHEY
  • 5 POSTS
I understand, I guess my neighbor and I can give it a shot. Anything else you think it might be just in case that fails to work? Just trying to get a nice little list of what it could possibly be.
Sep 13, 2010 at 3:11 PM
If it continues last resort do a block and pressure tests
Sep 13, 2010 at 6:37 PM
FHEY
  • 5 POSTS
Just some more updated information. I looked at the car this morning and noticed that all the coolant I had put in it was gone! So maybe there is a leak? Or something with one of the hoses? I did notice a little puddle by the front left tire but not massive. Also, there's a red light that comes on in my car I forgot to mention. It's located on the right side of my dash where all the little oil lights and stuff come on, i think maybe it has something to do with the radiator? I'm not sure what it is. I took the car on another run today, just filled it up with water and drove it around for about a half hour. Sure enough it got very hot again, actually got to the red this time, and when I was finished driving all the water was gone. Maybe this can help you guys narrow down on what the problem is. Thanks!
Sep 13, 2010 at 11:35 PM
Find the leak and fix it, if there's no leak do my last suggestion.
Sep 14, 2010 at 12:21 AM
FHEY
  • 5 POSTS
One more thing to add, my friend noticed that there is a lot of back pressure in the resivour, what could be a cause for that? Maybe that's the problem?
Sep 14, 2010 at 1:08 AM
