1998 Oldsmobile Cutlass headlights
1998 OLDSMOBILE CUTLASS
JEREMYEWARD
Electrical problem
1998 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
one headlight went dim for some reason. when i replaced the bulb the problem didnt fix. what could be causeing this to happen
Jul 18, 2010 at 3:37 AM
EDWARD.S
  • 166 POSTS
Hi, Check The Ground To The Right Front Headlight, Remove Headlight, Look At Connector Make Sure Three Wire Connector Is Not Burned Or bad connection.If Ok ,Take A Jumper Wire ,Go From Battery Ground To Black Wire On ThreeWire Connector. If Headlight Get bright Then. Then You Need To Repair The Ground Wire To The Headlight.On The Three wire Connector , One Wire Is Low Beam , One Wire Is high beam ,And Other wire Is Ground. You Can Run A New Ground To The Body Of The car If Needed,
Good Luck,
Edward S.
Jul 18, 2010 at 5:04 AM
