firing order?
1998 OLDSMOBILE CUTLASS
123,704 MILES • 6 CYL • FWD • AUTOMATIC
ANABELL
removed heads from a 3.1 liter took spark plug wires off coil packs did not mark them and the numbers on the coil packs r not the orginal james
Nov 22, 2008 at 6:38 PM
Hi:
Standing in front of the vehicle looking at the the coil packs, there are three of them. From left to right, the first coil pack is 1 & 4, the second coil pack is 6 & 3, and the third coil pack is 2 & 5. Now still standing in front of the engine, the first three cylinders in front of the radiator are 2,4 & 6 and the last three near the firewall are 1,3 & 5.
The firing order is 1,2,3,4,5,6 if it is a 2.8 or 3.1. What you did not say is what engine it has (2.8 VIN "W" or 3.1 VIN "T")
Let me know if this helps.
Dec 11, 2008 at 4:25 PM
ZELAYA
Electrical problem
1995 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
Please I need the wiring order diagram for this 1995 Cutlass with 3.1 V6 engine.
Thanks in advance
Aug 1, 2020 at 12:21 PM (Merged)
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_31_ciera_1.jpg
My info showed the above for a 3.1 ciera.
LDOWNER10
1994 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
what is the firing order for 1994 oldsmobile supreme cutlass 3.1 v6
There you go Merry Christmas
https://www.2carpros.com/forum/automotive_pictures/12900_fo_77.jpg
PISTACHIORICAN
I need to know the order of which the spark plug wires are put into the engine.
JDL
  • 16,098 POSTS
Hi, which cutlass do you have? What I looked at was cutlass ciera, 3.1L vin T
https://www.2carpros.com/forum/automotive_pictures/170934_ciera_firing_order_1.jpg
EDIEGO
I need to know what the firing order for the car is so that i can double check and make sure that its correct.
BMRFIXIT
  • 19,053 POSTS
[quote:4910738a59="ediego"]Engine problem
1986 Oldsmobile Cutlass 4 cyl Front Wheel Drive Automatic 30,000 miles
I need to know what the firing order for the car is so that i can double check and make sure that its correct.[/quote:4910738a59]
4 cyl firing order is 1 3 4 2
let me know if need more
good luck
MIKE STEEL
need firing order for 1985 olds. cutlass v6. please send firing order for distributor cap.
Hey Mike, Here is the firing order and distributor rotation diagram you requested for a v6 Gm. Let us know if you need anything else we are here to help.
https://www.2carpros.com/forum/automotive_pictures/561653_firing_order_85_38_1.jpg
THIZZLLE
i know the firing order for my car its 1,6,5,4,3,2 but i need a picture or something cause i dont know where these are like what wires is #1,6,5,4,3,2 and where is #1 wire is it the one on the left closest to the bumper or closest to the windsheild i dont know?
i replaced my distributor cap and i thought i put wires on in the right order but theres a clicking sound from it and my friend said i put the wires on wrong thats why i need to know which wire goes where
BMRFIXIT
  • 19,053 POSTS
best i can do hope that help
https://www.2carpros.com/forum/automotive_pictures/99387_olds_2.jpg
