1998 Oldsmobile Cutlass Antitheft System Help
1998 OLDSMOBILE CUTLASS
BUCKY20081
Electrical problem
1998 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
The car is a 98 olds cutlass. The ignition switch where the keys goes in had recently locked up. I bought a used one from a junkyard and installed it correctly. The engine will turn over and try to start but it wont ever keep running. The theft system light flashes all the time. Is there any way possible that that can be bypassed or reset? Is that what is causing it not to run? I tried a screwdriver on the battery ground but it didnt help. Any advice or answers would be gratly appreciated. Thanks!
Apr 2, 2009 at 5:43 PM
BRANKO
I had probs with my "99 Cutlass. Instead of waiting 20 minutes for a system reset, I"d disconnect Bat + and hook it back up. That would clear anti-theft code and staart the car.
Apr 9, 2009 at 2:00 AM
