1998 Oldsmobile Cutlass A/C switch faulty
1998 OLDSMOBILE CUTLASS
40,000 MILES • 4 CYL • 2WD • AUTOMATIC
JEWELS4JC
I was told that it is a common problem in the olds that the switch goes bad. A/C kept cutting off. It was replaced just b/4 I took it on the highway on Sat., and I broke down due to engine over heating. The belt had come off and I was told by the police officer that it runs the whole engine. He said that to repair the A/C the belt had to be removed and, apparently, it had not been reinstalled correctly. Is this true? I had it towed a hundred miles back to the repair shop.
May 26, 2009 at 5:47 AM
LEGITIMATE007
  • 5,121 POSTS
yes everything that was said is true , but your a/c cutting off could be other things like not enough pressure in the system(refrigerant),possibly a leak if this is the case, but yes one belt controls the whole system.
May 26, 2009 at 5:54 AM
JEWELS4JC
Thank you for your prompt response. I am hoping that the repair shop will fix my car and own up to their mistake.
I asked them if they had checked the freon level when I picked up the car and they hadn't. He just said it is blowing cold air. Incredible.
May 26, 2009 at 6:16 AM
LEGITIMATE007
  • 5,121 POSTS
typical, keep in touch
May 26, 2009 at 12:53 PM
