Disconnect the negative battery cable.
Drain and recycle the engine coolant.
The coolant drain is located on the radiator mount. Loosen but do not remove the petcock. (Radiator support removed for photo only)
Disconnect the upper radiator hose from the radiator.
Remove the upper transaxle cooler line from the radiator.
Remove the coolant surge tank hose.
Detach the cooling fan electrical connections. Unfasten any lines or conduits anchored on the fan body.
Remove the bolt securing the A/C line to the fan shroud near the coolant surge tank. Refer to the accompanying figure.
Remove the fans
Raise and safely support the front of the vehicle securely on jackstands.
Remove the lower closeout panel.
Remove the lower radiator hose and lower transaxle cooler line from the radiator. Plug the transaxle line and fitting
Remove the bolts fastening the condenser to the front of the radiator and secure the condenser to the vehicle with wire
Remove the lower radiator mounting panel.
Remove the radiator from the vehicle
To install:
Installation is the reverse of removal
Feb 22, 2010 at 9:58 PM
