turn A/C to full blast. fan should come on. if not, supply 12v power directly to fan motor. if fan comes on then check fuses and relays. if doesnt come on replace it.
Mar 9, 2010 at 5:39 PM
STOGYE
MEMBER
and if the a/c hasn't worked in two summers?? this tests fan but what about the sensors just cause fan works with 12 volts doesn't mean it works WHEN it should
