I have a 1997 Oldsmobile Cutlass Supreme. In December of 2007 I had a remanufactured transmission put in. About 2 weeks later, the car began having trouble starting. The battery seemed to be working fine, so I assumed it was the starter. I took it into a mechanic who said it wasn't the battery or the starter, it was the ignition cylinder and he replaced it for 340.0. Less than 20 minutes later the car did it again, I took it back and this time he said that he thought it was the anti-theft device causing the trouble and asked me to bring it back the next day so he could install a bypass switch. The next day, he wasn't there but another mechanic said it was a faulty relay-switch so installed a new one. Then he came out and told me the car wouldnt start AT ALL. I left it there over the weekend, and now he says when he came in this morning the battery was completely dead. How can that be when he said it was fine 3 days ago? Now he says he's charging the battery but he STILL doesn't know what's wrong. He says its not the starter or the fuel pump or the anti theft device. What else could it be? Please give me some advice, I'm so frustrated. Should I have it towed to another shop? Is there anything you can suggest that he check? Thank you. Sorry this was so long.
Feb 18, 2008 at 4:24 PM
