when i stop at a stoplight the rpm fluctuates up and down , just enought that it is noticable. any suggestions ?
May 7, 2009 at 6:54 AM
CBUNCH
MEMBER
[quote:6cd5447318="e lafferty"]1996 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic 55000 miles
when i stop at a stoplight the rpm fluctuates up and down , just enought that it is noticable. any suggestions ?[/quote:6cd5447318]
Have you found the reason why it does this? i have the same problem and have been going the forums like no other trying to figure out this problem!
Sep 2, 2009 at 10:41 PM
SAFARI1988
MEMBER
try thr fuel injectors and fuel related things if that dosn't work sometimes if your brakes are good and your throttle is sticky it could bog down the engine
Sep 13, 2009 at 7:08 PM
CBUNCH
MEMBER
Oh we found out the problem it was the ignition module. It fixed everything. The no power, the rpms, was getting 10 mpg now getting 18. thanks tho
