1996 Oldsmobile Cutlass is the transmission slipping?
1996 OLDSMOBILE CUTLASS
200,000 MILES • 6 CYL • FWD • AUTOMATIC
DMICHAELSMITH
Hi. I have a problem with the transmission on this car. While the car has high miles, the transmission is a reman with less than 100k on it. The problem I experiencing, is that every time you make a sharp left turn, the transmission acts like it goes into neutral, as the wheels lose all power and the motor revs up. It occassionaly does it from a stand still or on right turns as well. when it does finally re-engage, it acts and shifts normally with no grinding or slipping. Could a bad transmission oil pump be suspect? Bad transaxle? Please help me!
Thanks!
Dustin
Oct 13, 2009 at 10:37 PM
Make sure the trans is full. Let me know what you find.
Nov 28, 2009 at 1:11 PM
DMICHAELSMITH
The transmission is full. I have also added TransEx. That seemed to help for a short amount of time, but soon went back to what it is now.
Thanks
Nov 28, 2009 at 2:08 PM
