1995 Oldsmobile Cutlass turn singles
1995 OLDSMOBILE CUTLASS
167,700 MILES • 6 CYL • FWD • AUTOMATIC
DIXIECHICK661
Hi, I bought my oldsmobile a year ago and my turns singles worked, however I parked it for the summer and when I went to drive it only my left turn single worked. now none of my turn singles work. my emargence flashers do work fine I have changed all fuses and the flasher fuse as well as bulbs. A friend has told me it sounds like my "flasher" went out I have no clue where to find the "flasher" if thats even what it is.
Mar 25, 2008 at 2:28 AM
LEGITIMATE007
  • 5,121 POSTS
it should be right underneath your steering wheel under the dash. if not there, then behind the glove box
Mar 25, 2008 at 1:06 PM
DIXIECHICK661
thanks if it's not the flasher do you have any idea to what it might be? i would like to check the small stuff first before spending alot of money on something be
[quote:08f0644332="legitimate007"]it should be right underneath your steering wheel under the dash. if not there, then behind the glove box[/quote:08f0644332]
Apr 4, 2008 at 9:47 AM
LEGITIMATE007
  • 5,121 POSTS
no that should do it
Apr 4, 2008 at 3:09 PM
