1995 Oldsmobile Cutlass TIMING BELT NOISE
1995 OLDSMOBILE CUTLASS
53,000 MILES • 4 CYL • FWD • AUTOMATIC
SUSANIO
MY BELT MAKES A LOT OF NOISE AT CERTAIN TIMES. DO PULLEYS NEED OIL? , DO YOU THINK THE BELT SHOULD BE CHANGED?
IT NEVER WAS.
Oct 11, 2010 at 10:11 AM
WRENCHTECH
  • 20,761 POSTS
Your car doesn't have a timing belt. It has a chain. If your hearing a belt noise, it may be from the regular drive belt. Get a spray bottle with water and spray the belt with the engine running and see if it immediately stops indicating a belt problem.
Oct 11, 2010 at 10:31 AM
