1995 Oldsmobile Cutlass engine idles rough rpm drops a litt
1995 OLDSMOBILE CUTLASS
181,000 MILES • 6 CYL • 2WD • AUTOMATIC
REPARO50
Engline idles rough rpm drops a little when car is on drive or park. The car is consumming more gas. Also, the car has Check engine soon light on periodically. Wha can I do to correct this problem?.
Oct 8, 2010 at 8:46 PM
The idle issue could be the idle air control valve. Also, check for vacuum leaks. Finally, when the check engine light is on, the computer needs scanned. Most parts stores will scan them for free. Have that done and let me know what code they find.
Nov 2, 2010 at 8:34 AM
