1995 Oldsmobile Cutlass Car vibrates when I use the brakes
1995 OLDSMOBILE CUTLASS
85,000 MILES • 6 CYL • FWD • AUTOMATIC
NONOBEAN
I actually have two problems with my car one is that when I use the brakes my car shakes or vibrates and it takes longer than normal to stop I have replaced the tires, brake pads and rotors and it is still doing it. My other problem is sometimes usually when the weather hotter or colder than normal when I start my car the rpm's go way up and then down repeatedly and sometimes makes it stall out. When I start driving after a little while it goes away.
Dec 4, 2009 at 11:00 AM
Check the rotors for warpage and also for your idle problem the idle air control valve and throttle position sensor
Dec 4, 2009 at 11:40 AM
