1993 Oldsmobile Cutlass front end alignment
1993 OLDSMOBILE CUTLASS
SJMCMULLEN34
Steering problem
1993 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
outside of both front tires going bald , how do i adjust this , ALSO HAVE REPLACED O2 censor and plugs and fuel regulator and still have a problem with my car using to much fuel , where do i start to fix this?
Mar 16, 2010 at 10:37 AM
LEGITIMATE007
  • 5,121 POSTS
for the fuel, check the engine coolant temp sensor and pressure regulator. but the baldness, needs to be put on a computerized, alignment station in order to get it right, it will also need balancing, the other side of this, is, you may just need ball joints
Mar 16, 2010 at 11:17 AM
LEGITIMATE007
  • 5,121 POSTS
