1993 Oldsmobile Cutlass countinusly dies after a few mintues
1993 OLDSMOBILE CUTLASS
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
KONAN128
I have changed the spark plugs, fuel filter, o2 sensor, ran countless fuel injector cleaner through this car but it seems to have the same problem.. I need some help..
What happens is.. The car will run fine for a while then it will get a little heated up (driven a little) and it will start sputtering and it will countinuously die. It has a LOW LOW idle then if you push the gas it just kills it. Then if you sit there for about 3 minutes it will start back up again and run fine for a few.. then BAM same problem over and over.. Ran it on a scan machine down at the auto parts store and all it said was an o2 lean so now im out of ideas any help? Any help apperciated.. Thanks Guys :)
Jun 22, 2008 at 5:18 PM
Check the idle air control valve/throttle position sensor/EGR valve if it has one and clean out the throttle body/plate and also check fuel pressure-
Jun 22, 2008 at 6:09 PM
KONAN128
what exactly do you mean "check them" sorry im kind of a newb when it comes to car stuff.. thanks :)
Jun 23, 2008 at 11:41 AM
KONAN128
anyone? I donated to get 1 reply?? wtf..
Jul 1, 2008 at 5:39 PM
