1993 Oldsmobile Cutlass Car Shuts Off, then won't start
1993 OLDSMOBILE CUTLASS
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
MYAUTOBABY
19 Feb 2008
The car just shuts off when driving, then will not restart. It sat several days ago, then started like nothing was wrong. But, on the way home, it shut off again while slowing for a stop sign, and I had to have it towed.
Feb 19, 2008 at 9:15 PM
2CARPRO JACK
  • 11,533 POSTS
Need to check for spark and fuel pressure to see where to start with this.Is the check engine light on?If so need to scan PCM for codes, might not be a bad idea anyway
Feb 20, 2008 at 7:31 AM
MERLIN2021
  • 17,250 POSTS
Here's how to check those codes...
https://www.2carpros.com/forum/automotive_pictures/62217_GM_DLC95_Older_2.jpg
Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here.
Feb 20, 2008 at 7:52 AM
MYAUTOBABY
[quote:4f45419b6d="myautobaby"]Engine problem
1993 Oldsmobile Cutlass 6 cyl Four Wheel Drive Automatic 120000 miles
20 Feb 2008
No, engine light not on. Has spark, but no compression. Like it is not getting gas. So, it won't restart until it sits overnight. When it did start, it runs for about an hour, then just shuts off and stops.
19 Feb 2008
The car just shuts off when driving, then will not restart. It sat several days ago, then started like nothing was wrong. But, on the way home, it shut off again while slowing for a stop sign, and I had to have it towed.[/quote:4f45419b6d]
Feb 20, 2008 at 8:49 PM
MYAUTOBABY
20 February 2008
No, the Engine Light is not on. It has spark, but, no compression. Like it is not getting gas. It slows, then shuts off while driving, and will not restart. After sitting overnight, it starts up and runs for about an hour, then repeats the shutting off, and not restarting.
Feb 20, 2008 at 9:00 PM
2CARPRO JACK
  • 11,533 POSTS
Check fuel pressure with a manual gauge when it wont start, sound like the pump may be going out
Feb 21, 2008 at 7:24 AM
