1992 Oldsmobile Cutlass Turn Directional Lights Do Not Blin
1992 OLDSMOBILE CUTLASS
WHEELER459
Electrical problem
1992 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
I checked bulbs and they work. They stay on when switched up or down-they do not blink. The hazard switch will allow them the blink properly.
Jan 31, 2009 at 7:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty turn signal flasher. Located in front seating area, driver side, under dash, mounted on passenger side of steering column.
Thanks for using 2CarPros.com !
Jan 31, 2009 at 9:48 PM
WHEELER459
Do I have to take the steering wheel and column apart? Or is it truly under the dash?
Feb 1, 2009 at 7:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
No. The turn signal flasher is installed in a clamp attached to the base of the steering column support. Should be able to reach it from below.
Thanks for using 2CarPros.com!
Feb 1, 2009 at 1:15 PM
