1992 Oldsmobile Cutlass timing
1992 OLDSMOBILE CUTLASS
150,000 MILES • 6 CYL • FWD • AUTOMATIC
URBANC71
  • 5 POSTS
could the timing be so close that it looks like i have TDC but dont since it has coil packs do i still have an ignition control module?
Aug 10, 2009 at 12:47 AM
Put the engine no.1 piston on its compression/TDC pull the valve cover where no.1 cylinder and check both valves intake and exhaust for the no. 1 cylinder both should be closed. Now turn crank to align TDC/0.
The computer drives the DIS to fire the coil packs by sensing the CPS signal
Aug 10, 2009 at 1:23 AM
