1991 Oldsmobile Cutlass dignostic codes
1991 OLDSMOBILE CUTLASS
76,058 MILES • 4 CYL • 2WD • AUTOMATIC
SHANNON6978
I have a 91 Cutlass Calais. I have done the computer check for the codes. I have received many of codes. the code that I am at now is 4 flashes then 5 flashes. I can't figure out why is it running the way it does. If I'm not mistaking it means its running lean. what would cause this? I have replaced the Coil packs, Spark plugs,Complete tune up Injector, Ignition Module, Crank sensor, Throttle position sensor, Idle air control, Fuel pressure regulator, Fuel Pump/Harness, Fuel filter, Throttle body gasket, EGR valve, valve cover gasket, Cat. converter and the computer is new also. When I bought the fuel pump harness the wires were reversed and ran my pump backwards. I had some problems before that happened but since then its running really bad. when I reset then computer it runs ok for a minute but I still have to clear out the fuel. I can't push the gas pedal but only so far. 2 days ago it started stalling on me whenever I went from park to drive or let it idle (even when sitting still at a red light.). when I bought the car it would stall on me once it finally would warm up a little. once it cooled down for a minute. It has low miles on it. What is the problem with this car?
May 21, 2008 at 1:25 PM
LEGITIMATE007
  • 5,121 POSTS
how bout your fuel pressure regulator and o2 sensor
your o2 sensor could just be a little week causing it to run lean. your pressure regulator will do the same. I ll send you a video that shows how to check fuel pressure.
May 22, 2008 at 7:23 AM
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
check your fuel pressure here
