Hi, I've been getting air in my brake lines, mostly near my passenger rear caliper, and there does not appear to be any fluid leak. Reservoir level fluctuates with application of brakes but no change in overall level. I've replaced the brake master cylider about a month ago and rotors and pads all-around four months ago. Did not see anything to raise concern then. I do get engine speed fluctuation with the application of the brakes. May be a vacuum leak to the power booster. Any ideas? Could a potential vacuum leak cause air to get into my brake system, or is it likely a bad caliper? Thanks
Feb 27, 2009 at 4:05 PM
