1989 Oldsmobile Cutlass warm start up
1989 OLDSMOBILE CUTLASS
60,000 MILES • 6 CYL • FWD • AUTOMATIC
MRSIDEPOCKET44
i had charging problem so i replaced alternator and battery. drove it one day and then it wouldn't start after it warmed up.. i've replaced plugs. wires ,coil packs , ignition module, crankshaft position sensor, fuel pump, throtle position sensor, fuel pressure is 42 psi .. fuel injectors are spraying a good spray..all new parts.. car starts initially runs until it warms up then all it does is crank over will start after it cools down .any info will be appreciated thank you
Jun 29, 2010 at 9:16 AM
Have you checked the ignition module?
Jun 29, 2010 at 1:04 PM
MRSIDEPOCKET44
i had charging problem so i replaced alternator and battery. drove it one day and then it wouldn't start after it warmed up.. i've replaced plugs. wires ,coil packs , ignition module, crankshaft position sensor, fuel pump, throtle position sensor, fuel pressure is 42 psi .. fuel injectors are spraying a good spray..all new parts.. car starts initially runs until it warms up then all it does is crank over will start after it cools down .then it starts up and runs like a it should for aprox 20 - 30 mins
Jun 30, 2010 at 7:47 AM
When the engine doesn't start, which is missing, fuel or spark?
Jun 30, 2010 at 11:15 PM
MRSIDEPOCKET44
yesterday i discovered that after running for 20 mins, i checked for spark and there is NO SPARK untill it cools down
Jul 1, 2010 at 10:13 AM
That is helpful. I realize you replaced the ignition module, but I suggest returning it (hopefully under warranty) and trying a different one. That is exactly what they do. Also, check the wiring to it. Make sure all connections are good and none of the wires are broken.
Jul 1, 2010 at 1:24 PM
