i had charging problem so i replaced alternator and battery. drove it one day and then it wouldn't start after it warmed up.. i've replaced plugs. wires ,coil packs , ignition module, crankshaft position sensor, fuel pump, throtle position sensor, fuel pressure is 42 psi .. fuel injectors are spraying a good spray..all new parts.. car starts initially runs until it warms up then all it does is crank over will start after it cools down .any info will be appreciated thank you
Jun 29, 2010 at 9:16 AM
