1989 Oldsmobile Cutlass coolant system
1989 OLDSMOBILE CUTLASS
138,000 MILES • 6 CYL • 2WD • AUTOMATIC
89_CUTLASSSUPREME
i have a 89 cutlass supreme when i bout it the engine light was on i replaced the upper intake manifold gasket both coolant temp sensors/sender the pigtail wire for the sender and the thermostat.
The engine light is now off but everytime i drive anywhere no matter the distance the temp light comes on. anyone kno what could be wrong?
Jul 7, 2009 at 11:10 PM
Does the engine actually overheat?
Aug 10, 2009 at 12:27 AM
89_CUTLASSSUPREME
no it reads around 216 then one of the fans kicks in. i was told that thats ok. but i am wondering why the light stays on.
Sep 29, 2009 at 10:17 AM
Actually, that is getting hot, but not hot enough to set a light. You may want to try replacing the temp sending unit. It may be causing the light to come on too soon.
Sep 29, 2009 at 10:27 AM
