1989 Oldsmobile Cutlass
1989 OLDSMOBILE CUTLASS
50,000 MILES • 4 CYL • FWD • AUTOMATIC
GNTSFN379
  • 5 POSTS
i was driving along the highway and the motor just
started skipping and there was no power when i step on the gas pedal and car skips alot i have changed plugs,wires,fueal flilter
Aug 25, 2010 at 11:19 AM
WRENCHTECH
  • 20,761 POSTS
Is this a Quad4 engine?
Aug 25, 2010 at 11:50 AM
GNTSFN379
  • 5 POSTS
yes it is a quad 4
Aug 27, 2010 at 6:42 AM
WRENCHTECH
  • 20,761 POSTS
It is possible to have a bad coil but not real likely. I have seen this many times. What you need to replace it the white plastic coil housing. On that engine it acts as a distributor cab and cracks internally.
https://www.2carpros.com/forum/automotive_pictures/561653_Quad_4_ignition_1.jpg
Aug 27, 2010 at 6:48 AM
GNTSFN379
  • 5 POSTS
will that help with the power when i step on the gas pedal
Aug 27, 2010 at 7:01 AM
WRENCHTECH
  • 20,761 POSTS
Of course, if it fixes the miss.
Aug 27, 2010 at 7:06 AM
GNTSFN379
  • 5 POSTS
the white coil housing was changed but still no power and skips
Aug 27, 2010 at 7:22 AM
WRENCHTECH
  • 20,761 POSTS
When was it changed? I just posted that at 7AM this morning.
Aug 27, 2010 at 8:21 AM
GNTSFN379
  • 5 POSTS
the guy that worke don the car said he changed wires,pugs,feul filter housing unit check fuel injeters,and computer but car stats fine idlesbad,skips,and no power when u step on pedal unless u put it to the floor
Aug 27, 2010 at 9:11 AM
