1988 Oldsmobile Cutlass engine is skipping
1988 OLDSMOBILE CUTLASS
132,678 MILES • 6 CYL • 4WD • AUTOMATIC
MIKE KELLY
my 88 2.8 L cutlass supreme act like it skipping and it hesitates when you open the throttle. I check the fuel pressure it's good 38 psi with vaccuam hose on and rise to 44 off. I have no way of checking the mem cal, the car also fill my crank case with fuel. I checked all the injectors and they all were clicking. could it be the the ECM is out of sequence in timing the injectors.
Mar 23, 2010 at 6:25 AM
FEELGOOD71
  • 32 POSTS
sounds like an ignition coil these engine were known for it.
Mar 23, 2010 at 6:38 AM
