1985 Oldsmobile Cutlass power steering belt
1985 OLDSMOBILE CUTLASS
BRADLEYYANCEY
  • 4 POSTS
Steering problem
1985 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
help i cant find the tension adjustment for the power steering belt to go on and it sure wont stertch can anyone tell me where the tension bolts are located or how to move it to get the belt on
Jun 20, 2008 at 8:33 PM
MASTERTECHTIM
  • 4,750 POSTS
behind the power steering pump down low there is a adjusting bolt. also on the front of the pump is the other bolt. be gentle when moving pump. dont pry real hard on it.
Jun 20, 2008 at 8:43 PM
BRADLEYYANCEY
  • 4 POSTS
[quote:c520c787b4="mastertechtim"]behind the power steering pump down low there is a adjusting bolt. also on the front of the pump is the other bolt. be gentle when moving pump. dont pry real hard on it.[/quote:c520c787b4]
i see two bolts on the front of the pump but they are behind the pulley i dont think i can get the pulley off are those the bolts ?? or are they the blots that attach to the arm that goes to the alternator?
Jun 20, 2008 at 9:03 PM
MASTERTECHTIM
  • 4,750 POSTS
lets start from the begining. does the vehicle have a serpentine drive belt or regular v belts? what size engine? the eighth letter of the vin number? does it have ac?
Jun 20, 2008 at 9:13 PM
BRADLEYYANCEY
  • 4 POSTS
[quote="mastertechtim"]lets start from the begining. does the vehicle have a serpentine drive belt or regular v belts? what size engine? the eighth letter of the vin number? does it have ac
there are 4 v belts one water pump to alt one water pmp to air pmp one water pmp to a/c compressor and this one water pmp to pwr steering pmp the 8th letter of the vin is an e hope that helps some i mat be able to upload a pic not sure how tho
Jun 20, 2008 at 9:27 PM
MASTERTECHTIM
  • 4,750 POSTS
does it look like this?
https://www.2carpros.com/forum/automotive_pictures/139033_2carpros_4.jpg
Jun 21, 2008 at 5:55 AM
BRADLEYYANCEY
  • 4 POSTS
yes it looks like that the #3 bolts have to come out?? they are behind the pulley and the rear ajd brackett is hard to make out still looking for that in the motor do you have to remove the bolts from the rear brackett and front brackett?
Jun 21, 2008 at 12:26 PM
MASTERTECHTIM
  • 4,750 POSTS
YES. NOT REMOVE THEM JUST UN LOOSEN THEM.
Jun 22, 2008 at 6:43 AM
