1979 Oldsmobile Cutlass NO BRAKES PRESSURE WHEN ENGINE RUNN
1979 OLDSMOBILE CUTLASS
BILLY SKINNER
Brakes problem
1979 Oldsmobile Cutlass Automatic 120,00 miles
I was told that I needed a mater cylinder which I changed out and I was also told that I had to bleed the lines which I did. When engine is off I have pressure but once the engine is running I have no pressure whatsoever.
Feb 1, 2008 at 5:08 PM
MASTERTECHTIM
  • 4,750 POSTS
you still have air in the system and or your porportioning valve may be stuck.
Feb 1, 2008 at 6:05 PM
