How do you remove the convertible top switch from the dash. It appears that there is a bezel that comes out first and then the switch itself has 2 screws that hold it in. Do you just pry the bezel out with a small flat head screwdriver or are there clips or something else holding it in place that are on the inside of the dash? Also, I do not see a fuse for the convertible top in the fuse panel, and I do not have the owner's manual. Where is the fuse for the convertible top? I think the top switch got stuck in the up position the last time I used the car, and now it won't work. If this did happen, is it more likely that I burned a fuse out, burned the switch out, or ruined the top motor? Thanks.
Oct 31, 2009 at 2:05 AM
