How do you fix a turn signal when the right turn signal blinks but when using left turn signal it just stays solid.?
Mar 10, 2010 at 7:37 AM
GETAWAYCARS
MEMBER
One of your bulbs on the left side is probably bad, may even be the rear one or a side marker, any light that is related to turn signals. Look at right side first with turn signal on to see what should be lit, then check the left side.
See the guides below, they will help you figure this out
My mom has a 1995 Oldsmobile Ciera. The right turn signal works but not the left. I changed both bulbs on the left but they are not blinking only the right? How do I fix this?
I checked the front bulb turn signal and it's working....so no issue there..
Mar 24, 2019 at 11:18 AM
(Merged)
HMAC300
CERTIFIED EXPERT
if the bulbs work then it's getting power try replacing the flasher
