Air Conditioning problem
1995 Oldsmobile Ciera 6 cyl Two Wheel Drive Automatic
The AC and engine cooling fan went out at the same time. I checked fuses, relays and the wiring. The i thought it may be the AC pressure switch, the charge level was very low, that explains the AC, but what about the cooling fan? i went to have the AC charged, now the compressor wont kick engage. So they could not charge the system henceforth wont disengage the pressure shut of switch. I am going to double check the wiring. The AC not engaging does not have anything to do with the cooling fan does it?
Jun 27, 2010 at 2:37 PM
