1995 Oldsmobile Ciera Broken seats
1995 OLDSMOBILE CIERA
GRANDPAZO
Interior problem
1995 Oldsmobile Ciera 6 cyl Two Wheel Drive Automatic
How do i repair them or even where do i go to get them repaired??
Sep 6, 2009 at 8:35 AM
JDL
  • 16,098 POSTS
Are you talking about an electrical issue or a broken seat bracket? If it is a broken seat bracket, on different makes and models, I have removed the seat from the vehicle and welded the bracket. You might talk to your local garage.
Sep 6, 2009 at 10:12 AM
GRANDPAZO
no the motor works. the top part of the seat just goes all the back.i have a stick holding it up..
Sep 6, 2009 at 2:28 PM
JDL
  • 16,098 POSTS
Yeah, if a metal piece is broken, see if somebody will weld it. You may have to remove the seat, on some makes and models, the bottom bracket is removable from the seat. Then you can take the bracket to a welder, most autoshops usually have a welder. On some older models, I have swapped out the whole driver seat assembly for the passenger seat. I'm not sure that is applicable on your vehicle?
Sep 6, 2009 at 3:04 PM
