1994 Oldsmobile Ciera radiator relay?
1994 OLDSMOBILE CIERA
30,340 MILES • 6 CYL • FWD • AUTOMATIC
CHEVYDAVE1957
Where is the relay for the radiator coolant fan located? Can I somehow adjust the temp that the coolant fan trips on at?
Nov 14, 2009 at 12:32 PM
JDL
  • 16,098 POSTS
Welcome to the forum, how many fans do you have? My info shows a primary fan and a pusher fan, looks like a different relay for each? One of the relays should be passenger side front, under the hood, relay pack. Look at the wiring colors at the connector, pink--red--dark green -- lite blue.
There may be some aftermarket radiator fans, where you can control the turn on temp? Other than that, I don't know?
Nov 14, 2009 at 1:05 PM
CHEVYDAVE1957
There is only one fan on this vehicle.
Thank You for your help.
I will check the relays with the corresponding wiring.
Nov 15, 2009 at 8:43 AM
