1994 Oldsmobile Ciera FLASHING DASH LITES AND SLIPPING GEAR
1994 OLDSMOBILE CIERA
135,000 MILES • 6 CYL • FWD • AUTOMATIC
GRUTOID59
I HAVE A RECURRING PROBLEM WITH THE ABS LITE COMING ON ,THEN THE AIR BAG LITE COMES ON FLASHING THEN IS STEADY ,THEN FLASHES AND GOES OUT. AT THE SAME TIME THE CHARGING LITE FLASHES INTERMITENTLYAND AS WELL THE GEARS SSEEM TO SLIP IN AND OUT. ALL THIS OCCURS SPORADICALLY. I HAVE JIGGLED THE SHIFT LEVER IN ALL GEARS,GONE OVER VERY BUMPY ROADS,BANGED ON THE DASH,JIGGLED THE KEYS IN THE IGNITION BUT NOTHING CAUSES THESE SYMTOMS TO OCCUR .I CANT DUPLICATE THE SYMTOMS. SO I HOPE YOU CAN HELP. THANX WILL I BE NOTIFIED THAT YOU HAVE RECEIVED MY QUESTION?
Mar 16, 2010 at 12:21 PM
Have you ever had any trouble with a weak battery?
May 20, 2010 at 8:15 AM
GRUTOID59
THANKS FOR THE RUNAROUND SUPPOSED TO BE FREE BUT I CANT FIND THE ANSWER TO MY QUESTION
Jun 2, 2010 at 11:33 AM
I'm trying to help. Have you ever load tested the battery?
Jun 3, 2010 at 12:29 PM
