1994 Oldsmobile Ciera bolt torque specs for intake manifold
1994 OLDSMOBILE CIERA
CCTUDY
Engine Mechanical problem
1994 Oldsmobile Ciera 6 cyl Front Wheel Drive Automatic
I need to find the bolt torque specifications for the lower intake manifold and the upper intake plenum for 1994 oldsmobile cutlass ciera.
May 2, 2010 at 7:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
tighten lower intake vertical bolts to 115 INCH lbs and diagonal bolts to 115 INCH lbs as well. the upper intake torques to 18 Ft. Lbs.
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_480.jpg
May 2, 2010 at 4:16 PM
