Engine Mechanical problem
1993 Oldsmobile Ciera 6 cyl Two Wheel Drive Automatic
This is my mothers car
The car will turn over but it wont start unless you spray starting fluid into the throttle body. Then you can rev it up, drive it, whatever u want. As soon as i shut it off it wont start and i have to spray it with starting fluid again. Ive cleaned the MAF sensor Replaced the fuel filter, and Checked the fuses. Im not a mechanic by any means so im getting a tad frustrated with this. Any help would be appreciated.
Thanks
Crossfire71
Thanks
Crossfire71
Apr 8, 2010 at 7:12 PM
