1993 Oldsmobile Ciera Spark plug wires
1993 OLDSMOBILE CIERA
164,000 MILES • 6 CYL • FWD • AUTOMATIC
JULIERANGO
The spark plugs #1,3, and 5 run behind a plastic cover in the front of the engine just above the header. How do I remove the plastic plate to release the wires?
Feb 15, 2009 at 6:02 PM
ARFSTROM
My 94 Olds Ciera has a push spot on the skinny side of the bracket. Use a small screw driver, and just press in, and pull the top off. Should pivot. Unless you broke the hinge side allready. (I did)
Arfstrom
Mar 25, 2009 at 9:43 PM
