1993 Oldsmobile Ciera Fuel system
1993 OLDSMOBILE CIERA
197,850 MILES • 6 CYL • FWD • AUTOMATIC
CHARMAINETERKELSON
My car has not been doing good we had noises for a while we replaced the fuel filter, and the the fuel pump and the spark plugs the fuel injecters and its having a hard to starting we get it started but we have to pump the gas and turn it on at least 4 to 5 times in the morning and its very hard to press on the gas pedal sometimes it wont go and at times it goes i dont know what it can be please help me
Sep 17, 2009 at 12:37 AM
JDL
  • 16,098 POSTS
Welcome to the forum, if the gas pedal is hard to push, maybe you need to check the throttle linkage at the throttle-body, under the hood. You can take the throttle-body off and give it a cleaning, make sure all passages are clear. Also, use a gage and check fuel pressure, 41--47 psi.
Sep 17, 2009 at 1:06 PM
