Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Oldsmobile
Ciera
Engine Cooling
Water Pump
Replace/Remove
1992 Oldsmobile Ciera water pump
1992 OLDSMOBILE CIERA
RRIOS
MEMBER
FOLLOW
1992 Oldsmobile Ciera 6 cyl
how do you remove it
Nov 10, 2009 at 12:04 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Nov 10, 2009 at 12:39 PM
RRIOS
MEMBER
unable to remove bolts on wheel what can i do
Nov 10, 2009 at 12:56 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
what problem are you having with the bolts? stripped, not enough access?
Nov 10, 2009 at 12:58 PM
RRIOS
MEMBER
pully turns as you try to remove bolts ,do not move , also by the way its a 94 not a 92
Nov 10, 2009 at 1:11 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
need to keep the drive belt on and tightened so you can loosen the bolts. then remove belt and finish removing the bolts.
Nov 10, 2009 at 1:16 PM
