1992 Oldsmobile Ciera Key locks don't turn with key.
1992 OLDSMOBILE CIERA
KTKCAD
Electrical problem
Someone tried opening the driver's door with a hanger and the key no longer turns the locking cylinder mechanism. I would suspect something mechanical but the passenger's door no longer works either. The auto lock and unlock works from within the car, as do the manual slide locks at every door. Fuse(s) are okay. Before I pull a door panel off I was wondering what I might be looking for? A special wire that holds the key cylinder in place? None of the keys we have that used to work work in any of the doors. They still work in the trunk however.
Apr 15, 2010 at 8:23 PM
Chances are they bent the linkage to the lock. Remove the door panel and check that. Also, make sure the linkage is all attached.
Let me know what you find.
May 20, 2010 at 8:07 AM
