1992 Oldsmobile Ciera battery troubles
1992 OLDSMOBILE CIERA
135,000 MILES • 4 CYL • FWD • AUTOMATIC
KK08GI
I just recently replaced the bettery and i had a small start up when i turned the ignition and then nothing, iver tried multiple times to re-start and nothing. all the electrical in the car is out. i dont know if its because it attached the terminals in the wrong order or if i tightened them too tight or if i blew out the ecs when i tried to restart. any advice to troubleshoot is appreciated. Thanks!
Jan 19, 2009 at 6:51 PM
JNOVACK
  • 723 POSTS
first check that the red is connected to the + and the black is connected to - then check voltage at battery and then check voltage at the power distrubution center under the hood also check ECM fuse in fuse panel
Jan 19, 2009 at 7:04 PM
