1990 Oldsmobile Ciera not getting fuel or fuel pressure
1990 OLDSMOBILE CIERA
PATI JO
Engine Mechanical problem
1990 Oldsmobile Ciera 6 cyl Two Wheel Drive Automatic
I have a 1990 Olds cierra wagon that just won't start unless I'm spraying starting fluid thru the air cleaner. I just swapped the fuel pump and that was a giant pain since the fuel pump that came out was from a '93. I'm wondering since there is such a difference in years where the part was concerned if there may be a reset somewhere that shouldn't be there too. If there was, where would it be? and the relay isn't where I expected it to be either. Any ideas on a location for that too? or why this thing still won't start? If it helps, there is the pump noise when I listen but no fuel pressure and I already swapped the filter. I'm stumped.
Jul 5, 2010 at 10:03 PM
Check the fuel pressure with a fuel pressure tester to verify if the fuel pump is producing the correct fuel pressure start here
Jul 6, 2010 at 1:05 PM
